1. HYDRAULIC OIL HV 32/46/68 are premium quality anti wear hydraulic oils
    developed for use in high pressure hydraulic systems operating under varying
    temperatures where small viscosity changes with fluctuating temperatures are
    preferred.
    HYDRAULIC OIL HV 32/46/68 oils are formulated with carefully selected base
    stocks fortified with additives and a very shear stable viscosity index improver to
    impart excellent protection towards wear, rust and oxidation.
    The viscosity improver reduces the viscosity decrease with rising temperatures.
    HYDRAULIC OIL HV 32/46/68 are formulated with field proven thermally
    stable,zinc based anti wear additives.
    HYDRAULIC OIL HV 32/46/68 provide excellent water demulsibility as well as de-
    aeration.
    The product effectively protects against rust and oxidation.
    HYDRAULIC OIL HV 32/46/68 can be used in hydraulic systems in stationary and
    mobile hydraulic systems, as well as for general machine lubrication.
