TOP NEW PRODUCT BALDWIN 2018
Тема в разделе "Акция", создана пользователем Shmell, 4 апр 2019.
  1. Shmell
    Shmell Administrator Команда форума
    TOP NEW PRODUCT APPLICATION GUIDE
    BALDWIN OE DESCRIPTION PRIMARY APPLICATION EQUIPMENT USED ON
    AIR
    RS4634XP DBA5114 Extreme Performance Nano Radial Seal Air Element Mack Trucks Trucking
    CA30131 P621097 Channel Flow Air Element Freightliner Trucks with Cummins Engines Trucking
    PA30170 180945802 Air Element M.T.U. Diesel Engines Construction, Marine
    PA30171 170941202 Air Element M.T.U. Diesel Engines Construction, Marine
    RS30181, RS30182 84072430, 84072431 Radial Seal Inner Air Element Radial Seal Outer Air Element Fendt Combines; Massey Ferguson, New Holland Harvesters Agriculture
    RS30187XP X011623 Extreme Performance Nano Radial Seal Outer Air Element Kenworth W900 Truck; Peterbilt 388, 389 Trucks Trucking
    RS30216 394690 Radial Seal Outer Air Element Dynapac Compactors, Rollers Construction
    RS30225, RS30226 87741560, 87741569 Radial Seal Outer Air Element Radial Seal Inner Air Element International, New Holland Tractors Agriculture
    PA31004 70024177 Primary EnduraPanel Air Element JLG SkyTrak 6036, 6042, 8042, 10042, 10054 Telehandlers Construction
    PA31005 700738184 Secondary EnduraPanel Air Element JLG Forklift, Telehandlers; Massey Ferguson Windrowers; Skyjack Telehandlers Agriculture, Construction
    PA31006 700738183, 5288553, 70024175 Primary EnduraPanel Air Element JLG Forklift, Telehandlers; Massey Ferguson Windrowers; Skyjack Telehandlers Agriculture
    PA31007 5310325 Secondary EnduraPanel Air Element JLG Forklift; Massey Ferguson Windrowers; Skyjack Telehandlers Agriculture, Construction
    FUEL
    BF1347-O S3226T Fuel/Water Separator Spin-on with Open End Freightliner Chassis; Freightliner, International, Kenworth Trucks; Thomas Buses Trucking
    BF1360-O R90S Fuel/Water Separator Spin-on with Open Port for Bowl Blue Bird All-American, Vision Buses Buses
    BF46062 TP3018 Fuel/Water Separator Spin-on with Open Port Chevrolet, GMC Pickups, Vans Automotive
    BF46071 9584770115 Fuel/Water Separator Spin-on with Bowl and Drain Mercedes-Benz Trucks Trucking
    BF46072 WK1060/1 Fuel/Water Separator Spin-on with Bowl Volvo Construction Equipment Construction
    BF46083-O 1393640 Fuel/Water Separator Spin-on with Open Port for Bowl Scania Trucks Trucking
    BF46085 LW10429946 Fuel Spin-on John Deere Dozers; Liebherr Equipment Agriculture, Construction
    PF46088 8981596930 Fuel Element Toyota, Isuzu Applications Automotive
    BF46098-O ABP/N122-R50419 Fuel/Water Separator Spin-on with Open Port for Bowl Freightliner Century Class, Cargo FC80, Cascadia Trucks Trucking
    BF46099-O AT365869 Fuel/Water Separator Spin-on with Open Port for Bowl John Deere Equipment Construction, Forestry
    BF46100-O AT365870 Fuel/Water Separator Spin-on with Open Port for Bowl John Deere Equipment Construction, Forestry
    BF46113-D 245005 Fuel/Water Separator Element with Drain Gehl Loaders Construction
    BF46117 22474709 Fuel Spin-on Mack, Volvo Trucks Trucking
    BF46129 5365988 Fuel Spin-on Freightliner, Kenworth, Peterbilt, Volvo Trucks w/Cummins ISX11.9, ISX15.0, QSX11.9, X15 Engs Trucking
    LUBE
    BD40027 RE530107, RE557343, RE561823, RE572785 Lube Spin-on John Deere Harvesters, Loaders Agriculture
    P40030 X57518300024 Lube Element M.T.U. Diesel Engines Construction, Marine
    HYDRAULIC
    BT23539 AY052 Hydraulic Spin-on Tigercat 630B Grapple Skidders, 720B, 720D Feller Bunchers Forestry
    BT23540 RE161181 Hydraulic Spin-on John Deere Tractors Agriculture
    PT23591-MPG 10324849 Maximum Performance Glass Hydraulic Element Liebherr Dozers, Loaders Construction
    BT23542-MPG 84487937, 87413809 Maximum Performance Glass Hydraulic Spin-on Case-International Tractors, Harvesters; New Holland Tractors Agriculture
    PT23534 32/925140 Hydraulic Element J.C. Bamford Excavators Construction
    TOP NEW PRODUCT CROSS-REFERENCE
    BALDWIN - DONALDSON -FLEETGUARD -LUBER-FINER -MANN & HUMMEL -WIX
    BF1347-O P551857 FS19798 LFF5851 - 33813
    BF1360-O P551854 FS20028 LFF8063 - 33788
    RS4634XP DBA5114, P616691, P544563, EPG110278, EAF5114 AF25952M, AF26363, LAF5114MXM - 42808,542808
    CA30131 P621097 - - - -
    PA30170 B120472 AH24332 - C3111951 -
    PA30171 B105036 - - C27040 -
    RS30181 P781203 AF26215 - CF1570 -
    RS30182 P789638,P781199 AF26214 LAF5897 C281580 -
    RS30187XP P625128, DBA5295 - - - -
    RS30216 P785390 - - - -
    RS30225 - AF26345 - - WA10209
    RS30226 - AF26346 - - WA10210
    PA31004 - AF55020 - - -
    PA31005 - AF55312 - - -
    PA31006 - AF55021 - - -
    PA31007 AF55320 - - -
    BD40027 - - - W11011 -
    P40030 - LF17485 - HU7016X 57161
    BF46062 - - LFF6012 - 33960XE
    BF46071 P551086,P551360 FS20041 LFF5778 WK1060 WF1060
    BF46072 P551067 FS19532,FS19845 LFF5766 WK10601 33838
    BF46083-O - - - - -
    BF46085 P551033 FS19897 LFF9897 WK1150 WF10213
    PF46088 P505973 FF5764 WF8429
    BF46098-O P551857 FS19798 LFF5851 - WF10059
    BF46099-O - FS19754 - - 33986
    BF46100-O P551034 FS20127 - - WF10110
    BF46113-D - - - - WF10147
    BF46117 - - - - -
    BF46129 DBF6776 FF5825NN - - -
